Transmission lockup
Timepit
I’ve recently figured out a starter issue, a loose ignition wire. However, once the wire was repaired I attempted to start it, the engine barely turned over twice & then locked up. There is no transmission lock up alert across my dash, so I am speculating on the tranny. I’ve tried the remedy to unlock; key in the ignition, don’t turn over, press unlock on key fob.
No results.
Any suggestions?
